runs good at times then bad ??
Old Nov 6, 2008 | 03:41 PM
rics94 civic's Avatar
Default runs good at times then bad ??
i got a 94 honda civic ex /5 spd with 174.000 mi on it , here the problem , when you first drive it runs fine at first , then it kinda starts missin , not real bad , but comes ands goes . i replaced the ffuel filter , no luck , all plugs are look good .was running fine untili took off the spool valve to fix a oil leak , all i did was clean off gasket ,put a little silicone around it and put it bac together, then degreased the engine , all this started after that thought maybe had moisture in the dist cap , took it off cleaned it , noticed it had a little oil in the bottom of it ,but did`nt make any difference , could it be possible that i may have water in the fuel ?? please help
Old Nov 6, 2008 | 03:57 PM
Is the CEL ON (see link in my signature)?
Old Nov 6, 2008 | 09:06 PM
StifflersMom's Avatar
Cat Fuсker
It's not water in the fuel cause than it'd run like crap all the time. Does it get worse at certain RPM?
Old Nov 7, 2008 | 01:53 PM
no the cel isn`t on . but i figured it out , thanks everyone for the help . it was the #4 plug wire had some oil on it fron the groument in the valve cover , need to replace that , anyway thanks again
Chris236Mich
26
Dec 14, 2010 11:58 AM
fazerman
Jul 20, 2010 07:45 PM
84crx
Aug 13, 2009 11:36 AM
general23cmp
Dec 20, 2008 10:43 PM
SiX
Mar 12, 2008 12:14 PM
