01 Civic EX starts fine, runs for a while, then major loss of power while driving
I have a 2001 Civic EX. It just lit the "check engine" light and lost nearly all power. It eventually died. After sitting 5 minutes, it starts back up just fine, runs fine, check engine light is still on. Checked plugs, they were a gray/white color, cleaned them and reinstalled. Later that day, car started fine, after about 2 miles of driving had same power loss, max speed 20MPH at 2k RPM. Got home, let it sit, starts fine again but power loss happens within a few minutes while driving. Any ideas? I do not have the tools to pull error codes.
Thanks for the advice Ron. The codes from AutoZone are: P1362, P1361, & P1298. Other postings I've read seem to point to the distributor with the TDC sensor built into it. My Civic has 120k, never had a timing belt replaced. What would you advise? Could it be a timing belt issue if it comes and goes?
You don't have a distributor. The TDC sensor is on the driver side of the head. I don't think a timing belt problem would set these codes.
P1298 is a problem in the Electrical Load Detector (charging system) located in the hood fuse box.
Reset the ECU to see whether all three codes repeat.
FD3Savage
02-07-2021 02:42 PM
Chris236Mich
26
12-14-2010 11:58 AM
wookieneck
01-06-2009 06:38 AM
general23cmp
12-20-2008 10:43 PM
SiX
03-12-2008 12:14 PM
