Old Jul 7, 2008 | 06:18 PM
  #41
danomatic93's Avatar
June 2010 ROTM
Default RE: Danomatic'
I'm done with the center grill, no more mods to that. I'm done with the fogs, no HIDs or painting the cover.
My plans as of now are basically all maintainance plans, no major mods or conversions in the future. She's done.
Old Aug 30, 2008 | 01:09 AM
  #42
June 2010 ROTM
FINALLY, the after video of the twin loop exhaust:
Old Sep 5, 2008 | 09:06 PM
  #43
June 2010 ROTM
Got the Blox Toe Adjusters installed and got the alignment done too.
Plus, I finished this season's To-Do list!
Here's my TO-DO list for this season:
- A-pillar Gauges (oil press, voltage, A/F aka light show) DONE
- Skunk2 front camber kit DONE
- H.O.P. Center Conosle DONE
- Interior mounted antenna (I have no reception after I deleted my stock antenna, oops) DONE
- Skunk2 Coilovers DONE
- Replace front shocks to KYB AGXs DONE
- Convert an Auto ECU to Manual then chip it DONE
- Lips (Mugen front DONE, Type R rear)
- MORE Anti-theft measures DONE
- Skunk2 LCAs DONE
- Beaks Subframe reinforcement kit DONE
- 22mm ITR rear sway bar (and end links, bushings, collars) DONE
- Sidemarkers DONE
- Twin-loop muffler DONE
- Rear camber kit DONE
- Fender fix-up (Fiberglass X-1 style, I got them dirt cheap)
- Fuel Filter DONE
- Reupholster (the padding at least) my armrest. DONE
- Blox Rear Toe Adjusters DONE
Old Sep 5, 2008 | 09:14 PM
  #44
jpnolan's Avatar
Lookin good lookin good I like the side markers. Lets see the night rider status lights.
Old Sep 5, 2008 | 09:46 PM
  #45
June 2010 ROTM
LoL, I don't have the knight rider L.E.D. scanner on my car. I just bought it for fun. I might put it on my pop's work truck. I'm not sure yet though.
Current Mods List (as of Sept 6, 2008):
1993 / EX Coupe / 5-Speed PA4-B000 trans (Y8 trans)
Engine/Performance-related
D16Z6 w/ Y8 tranny
~4.2.1 Stainless Steel Header
~Cold Air Intake w/AEM Dryflow Filter
~Tsudo Stainless Steel Catback Exhaust
~Twin-Loop Muffler
~Ground Wiring Kit
~NGK Spark Plug Wires
~Billet Aluminum Short Shifter
~Breather Filter
~Magnetic Oil Drain Plug
~1 ¼” Aluminum High Performance Radiator
~Phearable ECU chip
Wheels/Tires/Brakes/Suspension
~Front Upper Strut Bar
~Rear Upper Strut Bar
~Front Lower H-Brace
~C-Pillar Bar
~22mm ITR anti-sway bar and endlinks
~Beaks subframe reinforcement
~Energy Suspension Shifter Stabilizer Bushing Set
~Skunk2 Adjustable coilovers
~Skunk2 LCAs
~Skunk2 front Camber kit
~Focuz Rear Cambet kit
~Blox Toe Adjuster kit
~KYB AGX Adjustable Shocks
~Rear Drum-to-Disc Conversion
~Front Brembo Slotted Rotors
~Rear Brembo Drilled rotors
SUMMER WHEELS
~Gunmetal 16" Motegi MR7's on Kumho ASX 205/45R16
WINTER WHEELS
~Bridgestone Blizzaks 14" on steelies
~Complete Energy Suspension Bushing Set and transmission mount inserts
Appearance/Exterior
~pearl white paint job
~Mugen front lip
~Type-R rear lip
~Billet Aluminum Battery Tie Down
~Billet Aluminum Oil Cap
~Billet Aluminum Solenoid Cover
~Spoon style power mirrors
~Painted calipers
~Rear Debadged
~Mesh Grill Mod
~Window Vent Visors
~Flip-Flop Trunk Kit
~Si style tail lights
~Retrofit Projector Headlights, blacked out
~6000k HID conversion kit
~OEM fog lights
~JDM thin side molding painted to match
~EK sideskirt mod painted to match
~Antenna Block off plate
Appearance/Interior
~Interior color swapped to Black
~98 GSR Integra Seats
~Carbon Fiber Gauge Bezel
~Super Bright White LEDs in cluster
~H.O.P. Center Console
~Carbon Fiber E-Brake Cover
~CF Shifter and e-brake boots
~CF armrest cover
~Rear interior brake light delete mod
~Skunk2 Weighted Shift ****
~Triple gauge pod (Voltmeter, Oil Pressure, A/F)
~Xenon, galaxy white Dome light
Audio/Visual
~Alpine deck CDE-9852 w/iPod direct connect
~Interior mounted antenna
~Rockford Fosgate components
~Alpine Type-S 6" 2-ways
~Alarms and Car Security
Old Sep 18, 2008 | 07:11 AM
  #46
June 2010 ROTM
Here's a video of an auto-x event this summer. I finally figured out how to compress video. Either way here you go:
Needless to say, I have to find a way to more securely mount my camera...
Old Oct 7, 2008 | 07:14 PM
  #47
June 2010 ROTM
I've been getting some new toys in the mail recently.
(Benen Tripod Strut Bar)
(the other one is already on the car)
I'm waiting for some LEDs before I start the cluster swap. I'll be doing a write-up for EGs as the ones out there blow.
Old Oct 7, 2008 | 07:22 PM
  #48
is that cluster a direct swap for you?
i wish i could swap clusters out but i have a del sol, which has a funny shaped cluster
Old Oct 7, 2008 | 07:29 PM
  #49
V8DIET's Avatar
Is that a teg cluster? That'll be a nice swap! Cant wait to see it.
Old Oct 7, 2008 | 07:59 PM
  #50
June 2010 ROTM
It's not a direct swap, but it is pretty straight forward for EGs and EKs
I will have to:
-modify the stock cluster's shroud (the clear plastic and gauge face frame) a little to accommodate the wider Integra cluster.
-cut back the Integra cluster's shroud
-cut, connect and solder the Integra pigtails to the stock harness
-make a clear plexiglas cover...
etc... It'll all be in the write up.
