Warped rotor, ack.
Old Nov 4, 2005 | 10:02 PM
  #21
absoulute's Avatar
Default RE: Warped rotor, ack.
i would have to recommend power slot rotors and hawk pads.........u don't want cross drilled if u ride them all year.
Old Nov 4, 2005 | 10:34 PM
  #22
StifflersMom's Avatar
Cat Fuсker
ORIGINAL: AgentofDarkness
Thats cause u rapidly heated them and rapidly cooled them, i hardly think that counts as normal, even for extreme braking.
Oh, I know that...I'm just saying that any rotor will crack if you do something incredibly stupid:-D
Old Nov 4, 2005 | 11:12 PM
  #23
cross drilled is a waste. most companies do it because consumers want it. they do not run any cooler, and the original purpose was to reduce weight, and to evacuate the gases that build up from burning the adhesive that holds the pad material together, it forms a layer of gas between the pad and rotor, and reduces the energy transfer, so the holes let the gas escape. now we have made the slotted rotors that do a better job. now, on the other hand, most of you will never crack a rotor, drilled or otherwise. but, in a real performance point of wiew, slotted and dimpled are the best. the dimples give a bit of extra surface area to remove heat, and the slots keep the pad face fresh. im not totally knocking D/S rotors, just that slotted is technically a better choice. hell, i have D/S on the rears on mine[&:] and yes, i have seen rotors crack, right along the slot lines. and they were very, very expensive rotors. lets just say the front two cost enough to turbo almost any one of the cars in here.
Old Nov 5, 2005 | 09:52 AM
  #24
AgentofDarkness's Avatar
ORIGINAL: sacicons
Wats that expensive about em? I saw 2 brembo rotors for like 150.
Old Nov 5, 2005 | 01:32 PM
  #25
amg6975's Avatar
ORIGINAL: Kolhoznik
Look at most AMG brake rotors...they're cross drilled and slotted
Nah dude, I have all stock brakes.
J/K... I love sharing initals with them.
Old Nov 5, 2005 | 04:22 PM
  #26
Cat Fuсker
ORIGINAL: amg6975
ORIGINAL: Kolhoznik
Now, why would you need rotors with that red air-brake on the back side??? [8D]
Old Nov 6, 2005 | 02:07 AM
  #27
ORIGINAL: sacicons
These werent for a Civic, and they werent Brembos. they were a pretty rare set of top end Eradispeeds (i think) on a Z06. granted, they would have been fine in normal street use.
MaximusFunk
Jun 11, 2009 05:08 PM
susanlucci845
Apr 16, 2008 07:06 AM
FlipHKD720
Mar 14, 2007 10:57 AM
Trey
13
Feb 18, 2007 01:56 AM
lazyzebra
Dec 30, 2005 10:28 AM
