what can i do with $1000???
Old Jan 14, 2008 | 03:17 PM
  #21
XNXIXTXRXOX's Avatar
Default RE: what can i do with $1000???
Dont do i/h/e if you plan to turbo, chances are all theywill goto waste because with a turbo, you will replace all of those when you install it.
Do a complete swap, dont do spread it out, you would probably get a trans anyway with a d16Z6, and it would be cheaper. Plus, you have to rip out the engine and do alot of workgoingfrom auto to man., you might as well get it all dont at once. much less hassle.
Old Jan 14, 2008 | 03:28 PM
  #22
SilverWrench's Avatar
Banned
you would do the tranny and engine swap at the same time, i don't think i will be able to afford a turbo for a little while, so i guess i would just leave it as a stock swap
Old Jan 14, 2008 | 04:17 PM
  #23
try to get an engine that comes with the transmission. you can find a lot of engines in good condition on ebay.
Old Jan 14, 2008 | 04:38 PM
  #24
Banned
Old Jan 14, 2008 | 04:41 PM
  #25
didder's Avatar
do a complete swap... then your up to say 127hp with a d16z6 or d16y8 or something
then with your 1000 buy i/h/e thatll bebetween$500-700 depending on how cheap you go,and get those sweet pulstar spark plugs they are like $24.95a plug and they give you 10% more hp and torque, from what ive read. now your up to $600-800
finally get yourself a chipped ecu from phearable, tell him your mods and he will send you a sweet basemap that will add another 10whp cuz he will correct your a/f for your i/h/e.. those are $200
theres your grand, after you do your swap of course, but it would at least put you up to being 130-140whp, which is as fast if not faster than a b16
unless your going big with a turbo, then ignore what i said, but if you want to go n/a and just want a little more pep in your step thats how i would do it... but i would have nitrous [sm=badbadbad.gif]
Old Jan 14, 2008 | 04:42 PM
  #26
That engine looks good, but remember you need the tranny and ECU also, so that will cost you $825 plus shipping andhandling(expensive)from that site. you might be able to find a better deal on ebay.
That turbo kit is good of course, but you can surely piece together your own kit for cheaper.
Old Jan 14, 2008 | 04:47 PM
  #27
ORIGINAL: didder
thats only 127HP to the crank, not the wheels though.
ORIGINAL: didder
You should buy the plugs that are indicated for use on your timing belt cover (one step colder than those if you're running turbo).
10% more HP and torque from sparkplugs can't be true.
Old Jan 14, 2008 | 04:50 PM
  #28
Banned
for a turbo can the same one be used for the d16z6 and d15b, i'm gonna look at the junk yard for motor and tranny too
Old Jan 14, 2008 | 04:54 PM
  #29
KoshaK's Avatar
If you dont find anything you can do with the grand, you could always give it to me..
  #30
didder's Avatar
they ignite 2x faster than normal plugs, making fuel ignite 2x faster, meaning your piston gets thrusted down harder burning the same ammount of fuel.. causing more hp and torque
pulstarplugs.com
108 or something at the wheels...
