question about Megan 4-2-1 header.
Old Apr 17, 2008 | 11:35 AM
sparkhard's Avatar
Default question about Megan 4-2-1 header.
I need to get a replacement gasket that goes between the header and the downpipe. The problem is every single time i call megan they tell me they are out of stock and should have some in by next week.... i swear to god they have been telling me this for about 5 weeks. so i was wondering if a gasket from another company or even those ones at auto zone would work okay ???
oh, its a 2000/ex/AT BTW
thanks
Old Apr 17, 2008 | 11:50 AM
Default RE: question about Megan 4-2-1 header.
hmm....i'd sell it for a one piece header. I've heard a couple stories about that happening with Megan headers. Copied from the intake FAQ also:
Note for installation of a two piece header, this is referring to the gasket between the two pieces of the header: Torque the middle bolt first to 15 ft. lbs. Then the remaining to 15 as well. Then after throttling the engine a few times to break the gasket in, torque all bolts down to 25 ft. lbs.
Might avoid blowing the gasket in the future.
Old Apr 17, 2008 | 03:58 PM
Well, I looked one day for a long time for one that would match and found nothing.
I went to auto zone and they had a huge sheet of gasket material for like 15 bucks. You might have to ask for them to get it for you, it was in the back. I went to walmart, bought aviation snips, came home and traced the old one onto the sheet, and cut a new one out. I put it on top of a block of wood and used a drill to drill the holes in the new gasket where the bolt holes would be, and used a drill to start the 2 exhaust holes, then cut them with aviation snips. I lightly used a rubber mallet to flatten the edges down after they had been cut.
You may or may not need the following, but I did this because I stripped the threads in the header joint flange and bolts had came off while driving, which is why my gasket blew:
I went to Ace and bought some grade 8 bolts a tiny bit smaller than the holes that were in the header joint, some lock nuts (the kind without the rubber ring), lock washers, regular washers, and some lock-tite.
When I put it all on I did it like this: (this is in order from the bottom side of the header joint to the top side)
Bolt, regular washer, header flange, gasket, header flange, regular washer, lock washer, lock nut
I put lock-tite on the threads also
PS Do all of this with the header not attached to the car, it makes it way easier to get the bolts torqued down.
Blackout 04
Jul 31, 2008 11:45 AM
00civ00
May 27, 2007 05:10 PM
97_ex
Mar 29, 2007 01:16 PM
memoz
Intake, Header, & Exhaust
52
Mar 4, 2007 01:26 PM
civic96RB
Oct 10, 2005 08:58 AM
