what cam should i get
Old May 26, 2008 | 12:57 PM
SovXietday's Avatar
Default RE: what cam should i get
Honestly, there's a tool designed for that job specifically. Either that, or you will need to use a socket but I don't remember ever having to on a Honda engine.
What you do is, you lay the head on the table. Fold up a rag and put it under the head in the concave portion for the valve that you are working on. Take the tool/socket, place it on the retainer, and using a good hammer give it a good hard whack and it should just dislodge and can be placed to the side with no problems. Do this for all 16 retainers/springs/valves.
If you use a socket, just watch for the keepers. They are small and they can shoot everywhere if you're not careful. If you're using the tool designed for the job you won't have any issues because they have a magnet that catches them but if you're using a socket just make sure they don't come out of the hole and shoot across the room. You will need them later.
Old May 26, 2008 | 02:11 PM
SilverWrench's Avatar
Banned
what would happen if i didn't change the springs and retainers?
Old May 26, 2008 | 02:19 PM
Mr Mobsta Man's Avatar
Float a valve...
Old May 26, 2008 | 02:32 PM
Banned
ok i just watched a video about vavle float, so it looks like if the springs aren't strong enough or get worn out they don't hold the valve in place that well, is this because the different cam pushes down the spring more causing it to wearout faster?
Old May 26, 2008 | 02:35 PM
Bigger cams open the valves farther and for a longer amount of time (duration and lift)
Old May 26, 2008 | 02:41 PM
Banned
gotcha, thanks everyone
Old May 27, 2008 | 11:34 PM
arust45's Avatar
ORIGINAL: Mr Mobsta Man
Generally the case, but turbo cams are high lift, short duration. Overlaphas a negative effect with a supercharged engine.
________
WEB SHOWS
Old May 29, 2008 | 07:30 PM
Banned
what is a good online dealer for parts, i'm trying cimotorsports.net but its not letting me put more than one item in my cart, so any suggestions would me appreciated
edit: nevermind i got it to work
itzcorky
Jan 1, 2011 09:53 AM
dustin_crxsi
Jan 26, 2007 12:59 PM
civicblend97
Apr 29, 2006 01:12 AM
Pete
Oct 13, 2005 11:32 PM
Dickie
Jan 16, 2005 05:56 PM
