How do you install a tach?
Old Jul 19, 2006 | 01:25 AM
jwsimons's Avatar
Default RE: How do you install a tach?
easier yet, get a cluster out of an si, its pnp
Old Sep 22, 2006 | 08:38 PM
yoRt's Avatar
sweet sounds easy enough
Old Aug 28, 2007 | 12:07 PM
EightyNineDX's Avatar
Will a guage cluster out of a '91 Si fit in my '89 DX hatchback with no modifications needed?
Old Apr 22, 2008 | 09:41 PM
gen3honda's Avatar
I know this thread is old but I figured its better to revive it than waste server space on a new one. This wire that you talk about, the blue one with silver rings, I'm guessing is the 'signal' wire for the tach. I know the color of the wire might be different, but is this 'signal' wire present even in cars without a stock tach? I have a 95 Civic DX with no tach, so would there be a wire for me to hook a tach to?
Old Feb 12, 2009 | 08:28 PM
cfro30's Avatar
I've got the same car, is this the best place to ****e in? I've read that you should splice in near the ECU.
Old Feb 13, 2009 | 03:59 PM
this thread is dead man
2005
anyway, in your gauge cluster wire harness is a baby blue wire. use that.
Old Feb 25, 2009 | 03:22 PM
PATCHES<97EK>'s Avatar
What if your guage cluster doesnt have a rpm guage?
Like mine I dont have a tac in my cluster and I want to change it to a si cluster
Old Feb 25, 2009 | 08:49 PM
you don't have to rewire anything if you're swapping clusters. 96-00 clusters are all interchangeable and the wiring is already there for you.
just plug it in like normal and your tach should work.
Old Feb 27, 2009 | 10:45 PM
either that wire or in your engine bay, on the driver side, near the fender, there will be a capped blue wire, it's just sitting to the side, thats the tach feed wire, you can either splce into the wire behind the cluster like Trust said or can splice into the one i mentioned
Stumasters
Jan 3, 2007 09:53 PM
caper10
Jul 12, 2006 11:58 AM
94DXProject
May 13, 2006 09:50 PM
importcivicus
Jul 17, 2005 10:43 AM
dalifts
Dec 16, 2004 10:34 PM
