Did I install my Tach correctly?
Old May 13, 2006 | 08:59 PM
94DXProject's Avatar
Default Did I install my Tach correctly?
First off, you should know that I never did any wiring before this becase I've always been afraid of making a mistake that I can't undo. Despite this, the tach seems to be working OK. Here's what I did. There are 4 wires.
-Ground...Attached it to the chassis. CHECK
-Green (RPM info)...Attached it to the blue wire on the distributor harnass. CHECK
-White (Light/Dimmer)...Attached it to one of the three wires in the dash dimmer harnass. The backlight in the tach works, but does not dim. UNSURE
-Red (Power)...Attached it to the red wire in my head unit's harnass. I couldn't find any other source for voltage. [] Will that be a problem? UNSURE
Any input would be great.
Old May 13, 2006 | 09:19 PM
mentaldis0rder's Avatar
Default RE: Did I install my Tach correctly?
didnt your tach come with instructions.. ?
Old May 13, 2006 | 09:35 PM
Yep. And thanks for the input.
Old May 13, 2006 | 09:39 PM
mill$civic's Avatar
yes you hook its up right..i have my tach light hook up to my dimmer too and i never notices if it dims when i dim the rest..but i never do that anways, and if you dont dim your lights..then thats good...but with the power wire being hooked up to your deck, does the tack only work when your deck is on ??, where your fuse box is there are spare pins, i would connect it to one of thos for a 12v source so whenever you turn your car on the tach goes on, but its up to you...and 1 more very important thing, did you fuse it?, if not..buy a inline fuse holder and a fuse (mine recommeded a 5A fuse) and put it inline with the power wire right before it gets hooked up to the 12v source
Old May 13, 2006 | 09:50 PM
Good info. Thanks!
ORIGINAL: mill$civic
Nope...there's always power going through that wire. I checked it with the tach before I made the splice.
The tach I got came with a built-in fuse. I guess that's not common?
2000black
Jan 26, 2010 01:01 PM
asechrist
Mar 23, 2009 08:54 PM
Seth2367
Sep 8, 2006 09:59 AM
Cleft_Asunder
Jun 2, 2005 11:41 PM
dalifts
Dec 16, 2004 10:34 PM
