how can i do this...
Old Jun 27, 2007 | 09:34 PM
runswit2guns's Avatar
Default RE: how can i do this...
where is access to the parking lights? thats what i wanted, but cant find a wire or its location on the fusebox
Old Jun 27, 2007 | 09:38 PM
jeff948594's Avatar
red w/yellow tracer behind fuse box.....probably under sill plate and it will be easier to get to there. are the neons in car our under car?
inside....under the dash
Old Jun 27, 2007 | 09:41 PM
jeff948594's Avatar
yeah the in car fuse box, it will be easier to find in the sill panel though trust me, hundreds of security\rs installs have taught me that,
Old Jun 27, 2007 | 09:44 PM
sorry, stupid question but what is the sill panel?
Old Jun 27, 2007 | 10:00 PM
jeff948594's Avatar
not a prob, its probably installer lingo, i dont even know lol
go to your car, open the drivers door, look down. it is the piece of plastic (that is the sill plate) that is on the edge of the carpet. it is held on with clips so if u be careful and pull it up and push the carpet to the side there will be a bundle of wires probably wraped in electric tape cut the tape open and be sure not to cut the wires.and it should be in there, use a DMM (digital multi meter) to check to make sure though.
Old Jun 28, 2007 | 09:25 AM
its an 04. there are no wires under the carpet
Old Jun 28, 2007 | 12:39 PM
jeff948594's Avatar
yes there are, are they in a loom or in a white sleeve, all the wires for the brakelights and if u have a 4 door all of the p-window, p-lock wires are there too along with a mess of extras for the door pins and everything
Old Jun 29, 2007 | 09:05 AM
ya thanks, i found them. they were running underneath the console and not next to the sill under the carpet. but thank you
Old Jun 29, 2007 | 09:16 AM
bpapa's Avatar
Member
If you really want to wire it that way, you can just get a relay from an aux fog lamp harness, easy as pie: power, p.lights, switch, ground, done.
Don't use a really high amp one tho!
civicxtreme
May 15, 2006 08:11 PM
