How Are these Specs For 6x9 Speakers!
Old Mar 5, 2007 | 08:14 PM
Bostonhoodhop's Avatar
Default How Are these Specs For 6x9 Speakers!
6 x 9-inch 400-watt 3-way Car Speakers
[ul][*]Sweet upgrade for any car audio system[*]3-way speaker design features 400 watts maximum output power[*]Speakers designed with fiber reinforced IMPP composite woofer with butyl rubber surround[*]50Hz-20kHz frequency response[*]95dB sensitivity[*]40-oz. magnet structure[*]25mm ASU voice coil[*]High output midrange with 66mm mylar cone[*]30mm PEI dome tweeter[*]Crystal blue audio level indicator [/ul]
Old Mar 5, 2007 | 08:31 PM
03civiclxcoupe's Avatar
Default RE: How Are these Specs For 6x9 Speakers!
what kind are they those could be really good top of the line or they could be $20 pair
Old Mar 5, 2007 | 09:34 PM
thats the thing the brand is Metric???? i dunno but they were on sale from $90 soo j/w
Old Mar 5, 2007 | 09:36 PM
jimijam's Avatar
Unless they are CES complaint, specs are whatever they want them to be.
Old Mar 6, 2007 | 04:47 AM
Chaos's Avatar
At 400W max. through a 3 way, I'm guessing about 100W RMS which means you will just be let down without a amp. Your head unit will probabily output about 45 W. If those figures are legit, then it is quite the good pair, that is assuming you got a good 600W max. amp to drive them.
Asster
Jul 31, 2008 09:49 AM
00IntegraLS
Oct 24, 2007 01:48 AM
00IntegraLS
Oct 24, 2007 01:45 AM
bigmikew1
23
Apr 12, 2007 10:37 PM
FishV12
Nov 8, 2006 08:49 AM
