kill switch voltage question?
Old Aug 4, 2009 | 09:52 PM
vonjason's Avatar
Default kill switch voltage question?
anyone know if it matters what voltage wire i use for a kill switch? or what kind of wire
Old Aug 4, 2009 | 09:54 PM
vonjason's Avatar
also where should i splice the wire from? where are a couple places i kind find the wire on my car??
Old Aug 5, 2009 | 04:24 PM
Kehoe's Avatar
honda-tech.com has a nice tutorial. Couple that with the one in DIY section that addiction made, that should get you started.
http://www.honda-tech.com/showthread.php?t=2076997
https://www.hondacivicforum.com/foru...ad.php?t=68897
Old Aug 6, 2009 | 09:55 AM
vonjason's Avatar
thanks i like that right up better than the one on this forum but it doesnt talk about relays?
the guy at autozone was like ugh the wire is going to melt if you dont have relays...?
i have no idea what hes talking about help?
thanks
Old Aug 6, 2009 | 10:27 AM
Kehoe's Avatar
thanks
Relay is a good idea. I setup mine recently without a relay, but used a pretty large gauge wire and it isn't too far away from the cut point. I would be more worried about whatever you use for a switch melting if it isn't a high enough amperage rating. Radioshack sells one that is like 12V 25A, more than enough for the fuel pump circuit as it shouldn't ever have more than 15A going through, and if it does it will blow the fuse under the dash.
I am actually considering rewiring mine to include a relay, not so much for worry of amperage, but as another layer of security. One idea I liked is wiring the relay into the radio wiring you would normally use for a power antenna or to switch on an amp (can't remember the exact name atm). If you have no face plate or the radio is turned off, no power goes to the relay, fuel pump circuit never opens up.
Just remember to be creative. A radioshack switch in between the rear seat and the side panel is posted EVERYWHERE. Something like Addictions is better. Something of your own is best.
Old Aug 6, 2009 | 11:40 AM
vonjason's Avatar
thanks a ton!
EJ8_Man
Feb 7, 2008 05:59 PM
1meanb18
Aug 2, 2006 05:41 AM
AgentofDarkness
Mar 28, 2006 12:10 AM
AgentofDarkness
Mar 25, 2006 07:05 PM
