make turn signals flash fast
Old Apr 16, 2007 | 09:41 PM
mill$civic's Avatar
Default make turn signals flash fast
Anyone know how to make them flash fast? Im not saying im going to do this, just want to know how to do it.
Thanks
Old Apr 16, 2007 | 10:08 PM
the727kid's Avatar
Default RE: make turn signals flash fast
I know on my Caddy it blinks fast when the blinker light on the tail light is out.
Old Apr 17, 2007 | 12:12 AM
BlackDX's Avatar
You can either swap a bulb for an led bulb (led's have lower resistance and cause fast flash) or buy the adjustable flasher controller that adjusted the resistance the flasher see's which in turn adjusts the flasher speed....
Old Apr 17, 2007 | 12:18 AM
danomatic93's Avatar
June 2010 ROTM
The blinkers flash fast when the resistance in the wires aren't compatible to the flasher module. That means if a blinker is burned out or removed, the resistance that the bulb provided ceases the resist. Then the blinker will blink super fast. There are a couple of ways to make yours blink fast without losing a blinker. You can replace some blinkers with LED blinkers that aren't D.O.T. or S.A.E. aproved. These normally have less resistance than regular bulbs. Or, you (the easier way) you can get a heavy duty flasher from an auto parts store. These flashers are usually used for trucks that have trailers with more lights/blinkers than usual. The heavy duty blinkers are pre-set for a higher the usual resistance. Since your car will have far under that resistance it will blink fast.
summary: buy a heavy duty flasher and replace yours with it.
Old Apr 17, 2007 | 12:33 AM
jhsplaya08's Avatar
just buy some led's and they will...mine blink very fast with led's in the taillight blinkers
Old Apr 17, 2007 | 09:34 AM
mill$civic's Avatar
ok thanks!
Old Apr 17, 2007 | 09:51 AM
FlipHKD720's Avatar
a few of my friends cars have them blink fast becasue of a CEL orsomething wrong with the car, kind of like an indicator. Now that i think about it, my dads truck has that.
Jack Brush
Apr 28, 2012 05:33 AM
dlion77
Jan 23, 2010 09:03 AM
burnoutNshootnos
Dec 25, 2004 10:07 PM
cass4403
Dec 15, 2004 11:34 PM
Rollinon17s150
Oct 20, 2004 03:14 PM
