need advice
Old Jan 1, 2006 | 11:17 PM
top99sir's Avatar
Default need advice
I am makeing some changes to my sisters 03hb sterieo. she has a 5ch amp running the componets and 2 ten inch R types. the two subs are a little under powered so I was thinking that if I put one 12 or 15 R type in theyre place it might drive the one sub a little stronger and sound better than the two 10s.
give me your input
Old Jan 2, 2006 | 04:32 PM
05reverb's Avatar
Default RE: need advice
you will still be under powering it with that amp, the new type-r's handle 500 watt RMS, so i'd get another amp for your 10's, it depends on how much ohms on the voice coils of your 10's, are they dual 2 ohm coils or dual 4 ohm coils? If they are dual 2 ohms, you can get a mono amp, but if they are dual 4 ohm, you can get a 2 channel amp.
Old Jan 2, 2006 | 06:03 PM
Remmy's Avatar
It sounds like you (or your sister) are going for major loudness. In that case. Go for Rockford Fosgate amps. Go for some Rockford Power Series to bump the trunk. I warn you though, it costs a pretty penny and not to mention the fact that you might need to beef up an alernator or add an extra battery.
On a personal note, I dont see the need to have more bass to the point that you cant hear the other sounds, but thats my opinion.
Old Jan 2, 2006 | 07:48 PM
top99sir's Avatar
the car has all R Type compontet as well so they scream alredy, just a little more bass to richen it up would help. I was hoping to keep the cost down by not having to buy another amp but if it comes to that I will.
Old Jan 3, 2006 | 12:30 AM
amg6975's Avatar
Actually, going from two subs to one would raise the impedence and then the one sub would get the same amount of power as one of the other ones. aka, you'd have half the power.
Old Jan 3, 2006 | 04:53 PM
05reverb's Avatar
actally type r subs are dvc, and you can get them in dual 2ohm or dual 4 ohm, so you can get the ohm load you want.
Old Jan 6, 2006 | 09:05 PM
padresfan1988's Avatar
I would go for a kicker amp. They just released the "ZX" series (replacing the KX) amps for the 2006-2007 series. Price wise, they arn't to bad, expect to pay around 200-300 hundred dollars.
Old Jan 6, 2006 | 11:55 PM
jhsplaya08's Avatar
go for alpine's v12 series amps. i doubt the 2 10's would handle 500 each so the mrd-m1005 is out of the ? so you might wanna go for the 600 watt one. that seems pretty good for 2 10's. it is a mono though so check and make sure the subs are 2ohm+2ohm. that would be 300w a piece.
boobeyes
Jan 20, 2012 12:51 PM
mcbride
EK Swaps
15
Sep 19, 2005 03:11 PM
Mongoose
Jun 24, 2004 04:58 PM
Fordmstang67
Jun 15, 2004 09:04 PM
