need help subs arnt working
ORIGINAL: Stumasters
The best way to run an amp's power system is to have 2 fuses, close to the power source, and the item being supplied. If you buy a kit in the store, they will come with a little in-line fuse holder for under the hood, run one end to your bat, the other to the little fuse connector. Most are tube shaped now, and have a round cylinder fuse inside, and 2 terminals on each side with a set screw.
Run that to your amp, and find a good frame or body ground in the trunk to ground the amp to. Make sure your ground is tight, very tight so it won't vibrate loose.
Your remote wire hooks up to your car's stereo, usualy a blue wire labeled remote, or +12 amp, etc.. This tells your amp to come on when your radio is on, and turns it off when its off. If you don't have a remote or can't find it, you can run it to any +12 output, like your aux power, but make sure its one that dies when the key is off.
Your RCA wire is your sound transfer, the signal from your head unit to your amp, telling it what notes and tones to play. Some amps offer a speaker-level input for signals, but these are worthless really, only for people with old cars or factory amp replacements. A good RCA should be gold plated and shielded, and about 20 feet long, 1 black or white plug, 1 red plug. Match these from your stereo output to your amp's input. Some head-units have a front and rear output, some even have a sub output. If you only have one, use that, if you have two I would go with rear.
If your amp uses a 30 amp fuse, and only 1 I would use a 30 amp fuse up front, if you have problems with it popping every now and again, try a 40 amp, some people have problems with smaller fuses, but if it pops constantly, check your power wire, its grounding somewhere in the vehicle, or on the amp itself due to a stray wire strand maybe touching the amp's body.
If that doesn't clear you up, post again, I will we will do what we can ! :-)
dave_57204
Apr 6, 2008 05:38 PM
mill$civic
Aug 25, 2006 07:16 PM
mill$civic
12
Apr 8, 2006 11:26 AM
