need some help
Old Nov 17, 2008 | 06:48 PM
808boi's Avatar
Default need some help
i got a 92 civic dx, 4 door. The sunroof is broken and i needed a new one so i went to a wrecking yard and looked but all they had is one for a 96 civic 2 door. i know that they were in the same gen so i bought it, but before i even try to install it, i want to know how likely it is that it will fit, it looks like it will, help plz if you can
Old Nov 17, 2008 | 06:52 PM
I don't know whether the sunroof will fit, but 92 and 96 Civics are 5th and 6th generations, respectively.
Old Nov 17, 2008 | 10:53 PM
As RonJ said, they are not the same generation Civic.
You thinking that they were the same generation leads me to believe that there may be a mistake in what year the Civic you got the sunroof off of was, since visually you can easily distinguish the generations and I think you probably know what the visual differences are (i.e. 6th gen has a front upper grille where the Honda emblem is, and 5th gens do not).
Are you sure the Civic was a '96 Civic?
If it was a 92-95 Civic, the sunroof will fit your '92. Actually, upon second thought... DX models do not come with a factory sunroof. Are you sure that the sunroof on your car is a Honda OEM sunroof and not an aftermarket installation?
boobeyes
Jan 20, 2012 12:51 PM
PineappleMan
Feb 24, 2010 03:38 PM
joelmatt89
Jan 26, 2009 06:08 PM
dfdon
Aug 15, 2007 03:39 PM
CivicCrazy
Nov 29, 2004 11:50 AM
