Problem with amp.
Old Feb 3, 2008 | 11:26 AM
Wahooman1213's Avatar
Default Problem with amp.
I am having a problem with my Rockford Fosgate P1000-1Bd amp. The other day i was listening to my music as i normally do, and suddenly the subs and amp turned off. I turned everything off and still no power. Tried again a few hours later.....still nothing. what could be wrong?
Old Feb 3, 2008 | 11:59 AM
Default RE: Problem with amp.
does the amplifier have POWER at the input power and does it also have power at the REMOTE turn on terminal?
check your fuses, and if the PROTECTION MODE light is on the amplifier than you could have some problems! might also want to check your speaker wires. if they touch eachother they could be shorting the amplifier out puting it in protection mode.
you realy have to check it out yourself to find the problem...
Old Feb 3, 2008 | 12:04 PM
What would the fuse look like if it was blown?
Old Feb 3, 2008 | 12:47 PM
ORIGINAL: Wahooman1213
the metal piece in the center of the fuse that internally connects the two terminals on the fuse will have a break in it, and possibly some black on the inside of the center of the casing. kinda like how the filament on a blown lightbulb looks.
Old Feb 3, 2008 | 12:51 PM
Littlehag's Avatar
you can't always see that it's blown, I'd use a multimeter for best results.
Old Feb 3, 2008 | 10:35 PM
rudedawwg's Avatar
there should also be a fuse under the hood really close to the battery connected to the power wire. most of the time when an amp blows a fuse its usually on the power wire. if you replace the fuse and it blows again immediately you have a short somewhere. if it takes a while you probably have your subs wired wrong
Old Feb 4, 2008 | 10:31 AM
Thanks for the help guys. It was a blown fuse, which I replaced, so now Im thumpin' down the road again.
TiaMarie
Sep 14, 2011 09:25 PM
CarlisleP&SPaddy
Apr 3, 2010 06:53 PM
enigma34
Jan 8, 2009 07:02 PM
Bostonhoodhop
May 18, 2007 02:13 PM
