Stereo Questions!
JXP340
Power output @ 14.4 VDC
(4 ohms).................60watts per channel rms
(2 ohms).................85watts per channel rms
(4 ohms) bridged......170watts both channels bridged rms
wala!
wala!
every amp has a minimum amount of of ohms that it can run in your case your amp can only run at 2ohms per channel but can run only at 4ohms when bridged. bridged is when you take the positive from one channel and the negative from the other and use those as your only posotive and negative it gives you the power from both channels
in your case i would recommend one 4ohm sub a 10 or 12 would run nicely
a 4 ohm sub will just work best something around 150 watts rms and 10 or 12 it doesn't matter and you just connect the posotive to the posotive terminal on the amp and the negative to the negotive
simons81
Apr 13, 2009 04:06 PM
corinne8
Apr 27, 2005 01:23 PM
