Stereo went out
Old Oct 15, 2007 | 11:01 PM
ltkenbo's Avatar
Default Stereo went out
For those of you who don't know me, I've got a '99 EX Sedan. Anyways, I have some cheap junkyard speakers in the back and up front I had just installed the left one. The back ones have been working fine for the last few months. I put the left on ein yetserday and everything was working pretty well (note: I am still using the factory "head unit") and I was playing my ipod through the tape player like I normally do, and it was working fine, when all of a sudden tonight, the audio just stopped. CD player turns on radio turns on, tape player turns on, but no audio. Anyone know what might cause this?
Old Oct 16, 2007 | 09:43 AM
Default RE: Stereo went out
I think if there is a short in any one of the speakers or the speaker wiring, the amplifier will completely shut down and none of the speakers will play. Most aftermarket HU's work that way so I would think the factory one would too.
Old Oct 16, 2007 | 12:46 PM
ltkenbo's Avatar
If I find the short how to I make the aplifier (which is technically built into the "head unit) come back on?
Old Oct 16, 2007 | 06:27 PM
finnstang's Avatar
If you find the short and correct it, it should just come back on by itself. You may need to turn the HU off and then back on again.
Old Oct 16, 2007 | 07:42 PM
ltkenbo's Avatar
I found what might have caused a short and fixed it. There are not other "shorts" that I know of since I haven't messed with anything else on the system. I'm think I'm just gonna get new stereo system eventually.
Old Oct 16, 2007 | 08:44 PM
Littlehag's Avatar
Not to be crude but with factory receiver and "junk yard speakers" I dono if it would be worth your time to continue looking for the problem. I think its the head unit myself...
Old Oct 21, 2007 | 03:48 PM
ltkenbo's Avatar
Yeah I've decided I'm gonna get rid of it and put a new one in once I get a job.
Old Oct 22, 2007 | 12:29 AM
ShadFX's Avatar
You can try this - Fix the short that you think is the problem, then disconnect the headunit (ie physically pull the cable out the back) and then leave it off for about 5 - 10 mins. After you have had time to go make a cup of coffee, go back out to the car and then re-connect the head unit. Completing this process should have reset the circuit protection system. If this doesnt fix it post here again.
Old Oct 22, 2007 | 03:38 PM
ltkenbo's Avatar
Nope nothing. I plugged it back in and plugged in one of the speakers and nothing. I don't think its the speaker either because I used a voltmeter to test the resistance and its still 4 ohms. Weird thing is when I turned on the CD player I put the voltmeter to the speaker leads and I got a constant DC voltate of like 3.3 V and when I switched it to AC it was virtually nothing.
Old Oct 22, 2007 | 04:09 PM
You should measure about 6 volts DC from every speaker wire to ground. Try unplugging the head unit and at the plug, measure resistance from every speaker wire in the car to ground. Should be open circuit. Then measure across each speaker, should be about 4 ohms. If the speakers and wiring are OK, must be a faulty head unit.
cowsgonemadd3
Apr 5, 2007 05:32 AM
zapman98
Apr 12, 2006 08:30 PM
Spark
Apr 7, 2006 06:46 PM
chester_d13
Sep 8, 2005 12:48 PM
baker7598
Mar 3, 2005 06:20 AM
