tuner not working
Old Oct 20, 2006 | 06:47 AM
natecivic92's Avatar
Default tuner not working
I checked and checked the antenna in the back of the radio its hooked up.What else could be the problem.The radio doent work but the cd and everything else works fine.
Old Oct 20, 2006 | 08:52 AM
mill$civic's Avatar
Default RE: tuner not working
do you have the antenna on the top of you car up?..because i no if mines down i will get NO radio , also..check the options on the deck
Old Oct 20, 2006 | 09:49 AM
I extend the antenna all the way out on top the car and even move it around a little and you can here like a close channel but lots of static.Can your antenna go bad?
Old Oct 20, 2006 | 12:50 PM
sillyredcivic's Avatar
Yes antennas can go bad. I replace them alot. Have a local audio shop check it out.
Old Oct 23, 2006 | 08:13 AM
I ohmed it and it was good.I then looked in the back of the radio and found a piece of the metal end.I then went to parts store and purchased a new antenna.Works great now.Thanks.
chloiebear21
Dec 24, 2012 11:46 PM
Juans_MX3
Apr 7, 2010 03:38 PM
gunaa
Oct 22, 2009 11:36 AM
chrisroug
Oct 2, 2006 11:36 AM
johnnywas
Nov 9, 2004 06:01 PM
