Will this work....
Old Sep 29, 2006 | 06:28 PM
Zer0Ale's Avatar
Default Will this work....
im stil not clear on the RMS btween amps n speakers so i was wonderin if this amp will b able to push these speakers front and rear. oh yea does it matter if the fronts are 4ohms and the rear 2ohms?
Old Sep 29, 2006 | 07:07 PM
mousetopher's Avatar
Default RE: Will this work....
that amp will be fine for the front speakers. But would probably underpower the rears. Just wondering why you are wanting different speakers front and rear though. Why not get the matching rears?
Old Sep 29, 2006 | 07:17 PM
dito id match both and run alpine front and back........
reason i wouldnt mix the ohm loads is cause the rears being at 2ohms will pull more power from the amplifier which of course inturn makes the rear speakers louder........ when you realy want the loudest speakers in the front.
basicaly your amp would be pushen the front speakers with 35watts rms and estimated around 70watts rms do the rear speakers
BUT the lower ohm load you get the more distortion is put out. which when you want some good sounding speakers id sugest keeping it at 4ohms...
Old Sep 29, 2006 | 08:23 PM
herbaleyes's Avatar
Why would you put more expensive speakers in the back?
Old Sep 29, 2006 | 08:48 PM
typical newbie..........
not trying to be mean dont get me wrong... hell you should see my 66impala radio i did in it! cheap 6x9s in the rear deck and two pairs of tweets in the front, and a center tweeter also.LOL VERY HARSH
Old Sep 29, 2006 | 09:05 PM
Zer0Ale's Avatar
yes i am a noob thats y im askin questions i want the right info b4 i go out n jus waste my money, so thanx for the help
x1mpr0x
Sep 4, 2009 07:44 PM
muuurph
19
Oct 25, 2008 09:09 AM
importcivicus
Mar 15, 2006 08:28 PM
lilol89crx
Jul 29, 2004 06:56 PM
drrocket0302
Jul 20, 2004 11:30 PM
