Canada, Over Seas & Elsewhere Not from the states? Everywhere else post here.
help with my 94 civic.
Old Feb 22, 2009 | 09:57 PM
Romeo1978's Avatar
Default help with my 94 civic.
help...anyone...
i just bought a 94 honda civic dx hatchback 5 months ago.
i really didn't looked under the hood or really inspected the car.
it's from a mechanic so i'm asssuming every single part of it is working fine.
silly me. FYI i really have small knowledge in car mechanics.
this winter i noticed that i'm loosing a lot of coolant w/c causes my car to overheat. so i have to fill it up every other week, this was only during the freezing temperatures.
when the weather wasnt that bad and my coolant level seems to be normal or maybe loses a little bit. i noticed that my radiator fan doesn't work. i looked at the fuse box and looked for the fuse for the fan w/c was okay.
two weeks ago when i was about to drive the car. it suddenly won't start.
it would turn but won't start all the way. my fuel pump is working. i took off the top bolt on the fuel filter and have it started and it squirted about 5 to 6 inches high. so there is fuel right? i checked the spark plugs and noticed it's
wet from gasoline. i did the spark plug test and there's no spark. checked the distributor cap and rotor. there are build up of some stuff on the rotor.
so i replaced the wires. bought the cap and rotor kit. but i can't take the rotor off because of the stripped head. i don't even know if its a positive or negative.
i think have to tear that rotor apart. or is it easier to take off the distributor?
if i'm guessing right. it's the ignition system that is causing the problem.
i recently bought a volt meter. but i don't know what to check for.
i haven't seen whats inside the distributor.
i did some research on the internet about my problem. it wasn't specific but some of it says that it's because of the main relay, ecu, ecm coil, igniter, etc.
i really didn't know that this stuff exist in a car.
i went to a car parts store and asked how much for a main relay for a 94 civic. he asked me "what kind or for what".
so..... we have different main relays in a car?
i really don't wanna spend too much money on this one or buy parts that doesn't need to be replaced. i hope i can pinpoint w/c part to buy.
i hope you guys could help.
thanks,
romeo1978
stevenc
Jun 25, 2008 09:57 AM
TDR05AL
Jan 18, 2007 03:21 PM
superballa22
Sep 18, 2006 05:06 PM
coolguy1234
May 7, 2006 08:31 PM
Jas10hon
Jul 4, 2005 10:35 PM
