3 bar map sensor question
Old Dec 7, 2007 | 10:28 AM
tombakers's Avatar
Default 3 bar map sensor question
when fitting a 3 bar map sensor where do you get your boost vacuum point from cause my standard map sensor is on the manifold and i need to leave it on to stop a vacuum leak obviously.The gm one is a vaccum tube fitting.can you use anywhere after the throttle plate to get this reading i.e fpr vacuum pipe just tee into this? hope this makes sense! thanks
Old Dec 7, 2007 | 07:18 PM
MY99SI's Avatar
Default RE: 3 bar map sensor question
a few of my friends use 3bar map's and they usually T into the BOV vacuum hose.
91_ef_hatch
Aug 2, 2009 12:29 AM
tombakers
Nov 26, 2007 04:09 PM
FlipHKD720
Aug 12, 2006 03:28 PM
00sithrottle
May 12, 2005 10:25 AM
red_sleeper
Jan 15, 2005 01:08 AM
