gulping gas
Old Jun 21, 2008 | 01:52 PM
p77iceman's Avatar
Default gulping gas
I have a 93 hatch back with a h22a swap. I might be getting like 25 miles to the gallon. I don't think it should be sucking down the gas like this. I can also smell the gas really bad when I'm at a stop sign or red light. Do I have a problem or does the h22a suck the gas like this?
Thanks
Old Jun 21, 2008 | 04:53 PM
Default RE: gulping gas
h22's get like 28mpg or something like that. You're probably running rich if you smell gas real bad. Either that or a fuel line leak... Both would obviously cause poor gas mileage.
Old Jun 21, 2008 | 05:00 PM
Yeah, sounds like your engine is running rich. Is the CEL ON?
Check for an exhaust leak around the primary O2 sensor, a stuck open PCV valve or leaking PCV hose, or a faulty primary O2 sensor.
Old Jun 21, 2008 | 07:11 PM
p77iceman's Avatar
I'm not sure what the CEL is so I don't know if it is on or not.
Old Jun 21, 2008 | 07:21 PM
It's a light on your gauge cluster with a picture of an engine. It turns on when you first start the car to test the bulb, and then shuts off.
Old Jun 21, 2008 | 07:26 PM
See link in my signature.
Old Jun 22, 2008 | 11:26 AM
Information at the link below suggests that checking your engine timing with a timing gun would also be a good idea:
https://www.hondacivicforum.com/m_592952/tm.htm
Old Jun 22, 2008 | 12:50 PM
p77iceman's Avatar
I checked the cel#. It was the vss- speed sensor. I'm not sure where that is or what to do about it.
Thanks
edwinss4
Dec 6, 2010 06:10 PM
burgernuds
Nov 6, 2008 06:07 AM
Sprite_15
Nov 6, 2007 04:18 PM
phsballer123
May 4, 2007 07:24 AM
CarmineD187
Jun 12, 2006 10:19 PM
