help asap
my ecu wont turn on. the bulb did not blow. i put in a new engine and started it. had some of the sensors work i think the map but it was idleing high and when i hit the gas my mph was showing my rmp...fuel lines are good fuel pump is good. ecu is good. now when i try and start it the ecu light dosent come on at all. pls help i need my car back on the road
tryed to delete them in advanced editing but didnt see it. if a mod want to delete it i give them permission. i didnt think it did it three times though didnt mean to. i jus need help with my car thats all.
so i did a little messing around and i took the wire from my fuel pump and touched it on to my ecu power source. my check engine light come on but i get this grinding noise from the main relay and it opens but dosent shut off.???? any clues.
soldout712
Oct 30, 2006 04:03 PM
