helppp
i have a 94 dx and i swapped in a b16a. the guy i got it from had it in a 95 ex. it turns over but wont start.. my injectors are not working. i know my old engine was dpfi and this is mpfi, but i got all(well most) the wiring out of the ex and i put it into mine.. it does the same thing now, but i have alot of plugs that i cant figure out where they go( like into the under dash fuse box).. they were not on my dx body harness. i also am using the fuse boxes out of the ex.... the injectors still dont seem to be working.. any advice?? it all ran fine in his car
Check fuses 31, 24, and 18.
Check the ground wire attached to the thermostat housing. It should be clean and tight.
Any CEL codes? Does the fuel pump prime? Is there spark at all four plugs?
i dont have the dash in because iv been totally redoing the car. im going to plug in the cluster tomorrow and check. yes i hear the pump and all plugs have spark.. i tried to listen for the click on the injectors and could not hear it.. thank you ill also check the fuses
YeeshY
Dec 15, 2010 09:58 PM
