Helppp!!! scawy noise :/
So the other night driving home i hit something, not sure if it was a rock or what.(only with the right rear tire)
anyway it left a ball/ bump on my right rear tire(next to my wheel)
and i'm thinking something from the hard hit messed up my suspension, cause every time i hit a bump or a pot hole or anything that is not flat i hear a loud thump or noise coming from the right rear suspension.
(checked it out but nothing was loose/broken)
anyone know what it could be?!?!?1
thanks.
thanks.
Did you test out the compression/rebound of that shock by pushing up and down on the back end? A blown shock can make a lot of noise, you may not be able to reproduce that noise without actually driving however.
Also check out the trailing arm bushing. A good chance yours was already in bad shape, might have been torn almost all the way through before. Check all the bushings on that corner.
ok after 45 minutes of my examination, i have found that the trailing arm bushing is pushed towards the inside of the car
pretty sure it's that.
going to fix that and she if that is forsure it.
thanks
thanks
YeeshY
Dec 15, 2010 09:58 PM
