I have no clue(car wont start if its hot, some times...)
Old Jun 5, 2007 | 08:00 AM
SiX's Avatar
SiX
Default I have no clue(car wont start if its hot, some times...)
So heres the issue, my car will not start, sometimes, when it is warm. Like I stop at the gas station fill up and get in and it wont start; it cranks but it does not fire, there is fuel (i think i hear injector pulsing when I step on the gas and am cranking the engine. After about 1 to 10 min of periodicle cranking my car will then start and run fine.
new cap
new rotor
new sparks
new wires
Any ideas, I want to find the source of this issue?
Old Jun 5, 2007 | 09:00 AM
riceburner700's Avatar
Default RE: I have no clue(car wont start if its hot, some times...)
how does it run while you drive it?
Old Jun 6, 2007 | 10:16 AM
SiX's Avatar
SiX
Runs great!
Idles at 2k on cold start but after 5 min of idling its down to 720ish and stable.
Plenty of pickup. Doesnt seem to be moisture related and it will only not start if its warm but its a not allways.
Old Jun 7, 2007 | 03:45 AM
What kind of plugs and wires did you put in? Also, check your grounds to make sure they're secure
Old Jun 7, 2007 | 03:54 AM
SiX's Avatar
SiX
Nkg plugs, bosh plat wires are fairly new.
the grounding cable between my car and the transmision is in rough shape but still makes a connection. ill have to look at the others.
Old Jun 7, 2007 | 03:59 AM
Ditch the Bosch wires, Hondas don't like bosche.
Old Jun 7, 2007 | 05:43 AM
importcivicus's Avatar
also check your starter cause the solenoid might be sticking. Im aslo a mechanic in the military that was my biggest issue with the trucks i work on out here so goto auto zone and have them bench test it.
justin07731
Jan 2, 2009 03:25 PM
flipperlazo
May 6, 2008 10:56 AM
n8te81
Feb 28, 2008 11:26 AM
jaymacf3
Jan 20, 2006 10:45 AM
dj_ipirate
Jan 17, 2006 12:04 AM
