idle going up and down???
Old Aug 29, 2006 | 02:38 AM
Ej1Rider's Avatar
Default idle going up and down???
ok after i switch the tranny from auto to 5 speed, when i started the car back, the idle goes up and down between 1500 and 900 rpm, could it be the ecu?? cuz im still running the p28 for auto
Old Aug 29, 2006 | 07:49 PM
Chimera02EX's Avatar
Default RE: idle going up and down???
normally an idle like that is casued by a vaccuum leak.
Old Aug 29, 2006 | 08:10 PM
finalimpact's Avatar
or fitv needs adjusting, or the iacv is dirty, or a vacuum leak like stated above. ive never had problems with idle hunting with any of my 5spd conversion with auto ecu's
Old Aug 29, 2006 | 09:12 PM
Pete's Avatar
get urself a can of intake manifold cleaner.......spray it on the vac lines and when it sputters, youve found a leak!
(Sacicions taught me taht one)
Old Aug 30, 2006 | 12:27 AM
Ej1Rider's Avatar
thnaks guys.... whats the fitv??
Old Aug 30, 2006 | 01:57 PM
Ej1Rider's Avatar
ok i found something... i found out that the idle purge solinoid ( or how ever you spell it ) one of the hose broke off of it and took the plastic tube with it....
Old Sep 5, 2006 | 03:55 PM
StreetGlow_ciVic's Avatar
yea def a vacum leak and it looks lyk u found the problem. get tht fixed for sure and ur idle should b fine.
the same thing happened to me but it was jusy from my car sitting for 8 days. mine would go from 2500-1500 up and down constantly. i just had to rev it high(almost redline) and it stalled twice but fixed itself and runs perfectly.
usless^^^ but thought it might have helped
-JP
1stHonda
Mar 23, 2021 12:07 AM
queenlowla
Jul 31, 2013 06:18 PM
puckfan80
Aug 23, 2010 07:04 PM
SPACEGUY18
Nov 20, 2009 02:01 PM
Esquirrel
19
Aug 14, 2005 11:16 AM
