idleing at 2k rpm
Old May 4, 2008 | 08:00 AM
lew1's Avatar
Default idleing at 2k rpm
hi there need a bit of helpi hav a civic coupe 1995-1998 with a d16z6 engine out of a 1992-1995.the problem iv got is that when u turn the key 1 click the rev counter goes up too 1 and stays there and then when u start the engine it goes up to 2 and idles there.but the engine is onyl idleing at 1k even tho the counter says 2 any help would be great thanks
Old May 4, 2008 | 12:22 PM
Default RE: idleing at 2k rpm
The blue wire connected to the igniter unit in the distributor sends the signal to the tachometer gauge. Disconnect this blue wire and then turn the ignition key to ON. If the needle still jumps to 1K, then I think you have a bad tachometer gauge. If not, then you may have a faulty igniter unit.
Old May 5, 2008 | 12:22 AM
lew1's Avatar
thanks i will try that today cheers
riverjamie
Aug 26, 2009 08:03 AM
davidb123
Mar 5, 2008 01:13 PM
93civicSI99
Oct 22, 2007 08:22 PM
NewClimber
Apr 29, 2007 01:47 AM
civickiller18
May 10, 2005 09:38 AM
