LIMP
Old May 24, 2006 | 01:42 PM
D16DAVE's Avatar
Default LIMP
WHAT IS LIMP MODE. I HEARD SO MANY DIFF THINGS. BUT I JUST WANNA KNOW THE TRUTH
Old May 24, 2006 | 01:45 PM
RaskyR1's Avatar
Default RE: LIMP
lol....something that Viagra will fix I'm sure
Sorry...couldn't resist
Old May 24, 2006 | 01:56 PM
Street Sniper's Avatar
Default RE: LIMP
Caps lock is on the left side, middle of your keyboard.
Limp mode is a set of fuel and ignition tables that your ECU uses when you have a CEL. If you have a CEL, then your ECU assumes that something is wrong with your car and basically goes into "safe" mode. Normally your ECU is getting information from various sensors (namely the o2 sensors) and making fuel/ignition adjustments on the fly, know as "closed loop," but in limp mode it reverts back to a pre-set, very safe set of "look-up" tables.
Savvy?
Old May 24, 2006 | 02:03 PM
neon3kgt's Avatar
Default RE: LIMP
depending on the code. you could drive your car forever with the light on... say, an evap code, doesnt affect the engine, doesnt pass emissions tests but it wouldnt be in limp mode then.
Old May 24, 2006 | 02:15 PM
D16DAVE's Avatar
Default RE: LIMP
i am running a code for the o2 sensor because of the goddamn header and downpipe and no cat
but what does this safe mode do for the vtec. does it still engage or just adjust the fuel and timing during the v tec engagment.
frankenstein616
Mar 22, 2010 04:49 PM
shiftbyear
Jan 7, 2010 10:24 AM
civic_turbo
May 2, 2008 07:08 AM
civic_turbo
Mar 29, 2008 08:24 AM
D16DAVE
May 24, 2006 02:06 PM
