NEED ECU Harness HELP!
Old Aug 14, 2006 | 10:30 AM
t34me's Avatar
Default NEED ECU Harness HELP!
Okay, as if blowing up my turbo was not a big enough problem, i have run into another one. Because decided to do it the right way and get a chipped up ECU, that meant my Apex-i VAFC had to go. Here is the problem: When the unit was installed, it was crimped very close to the actual plug, but now that i had to cut it out, there is no wire left to crimp the origional wires back together!! The harness is F**KED!!! Please help, i just want to set the car on fire at this point. Please just give me an idea what to do in the way or repair, or maybe someone out there has the ECU harness (95 SOHC VTEC) they would like to get rid of. Im just at a loss people. Ive spent so much money trying to repair this thing, and the only harness i have found is 1 on ebay, but he wants $150 for it. Just please give me options or suggestions.
Old Aug 14, 2006 | 10:40 AM
pWnEdU's Avatar
Default RE: NEED ECU Harness HELP!
There not even enough that you could solder it? If there's a stub down in there, then just strip a wire, stick it in there, and solder them.
Old Aug 14, 2006 | 10:51 AM
t34me's Avatar
I dont think there is even enough left to get the wire stripper in there to expose it
Old Aug 14, 2006 | 03:13 PM
pWnEdU's Avatar
...there sure is.
Old Aug 14, 2006 | 04:59 PM
t34me's Avatar
Ok, so fixable=good news. Now, for the second part. Is this as simple as unplugging the engine harness plugs and feeding through the firewall to get it out, OR does the ECU harness have branches into things under the dash?? THis might be a stupid question, but there is no way in hell im going to unplug the engine side only to find out i have to rip the dash apart to unplug the rest of the s**t. Let me know.
Old Aug 15, 2006 | 08:00 AM
Why are you taking it out?
Old Aug 15, 2006 | 03:06 PM
t34me's Avatar
Pwnedu offered to fix it for me, i just need to know that i can unhook it from the engine harness, pull it through the fire wall, and bam, thats it. Just please let me know if it plugs into ANYTHING besides the engine bay.
Old Aug 16, 2006 | 09:41 AM
Honestly, I don't know.. I've never messed with it to that extent before.
the_turtle
Apr 19, 2007 01:58 PM
Tonymore
Feb 22, 2007 03:05 PM
t34me
Aug 19, 2006 02:31 AM
Pimpson88
Jan 31, 2006 10:51 PM
bain0005
Jul 6, 2005 03:51 PM
