o2 sensor again
Old Feb 12, 2007 | 08:17 AM
stylincompact's Avatar
Default o2 sensor again
hey guys im boosting my 98 hx. had the d16y5 head now i have a d16y8 head manual tranny. anyone have any idea how i can run my second o2 sensor? or how would i wire the knock sensor wire in the harness..even better anyone have a diagram or the ecu plugs.
Old Feb 12, 2007 | 09:28 AM
FlipHKD720's Avatar
Default RE: o2 sensor again
www.o2simulator.com
www.o2sensorsimulator.com
if youre boosting i imagie you have an aftermarket exhaust, probably with a highflow cat. No matter how well the cat is working, you will still get a CEL light from the increased exhaust flow (specially cuz of hte boost). You will need an o2 simulator to correct the CEL, and technically once you wire the the simulator in, you can remove the sensor and just plug the hole (not neccesarry, but it will clean up some wires runnin around near your exhaust). There are installation diagrasm on those two sites ^ and if those sites arent enough, Google. it. GL
Old Feb 12, 2007 | 05:41 PM
so with the simulator i will still pass emissions correct?
Old Feb 12, 2007 | 06:23 PM
FlipHKD720's Avatar
yeah, the only thing it messed with is the o2 sensor signal. The cat will still do its job..
wil
Jan 18, 2013 04:27 AM
1992 civic driver
May 29, 2010 03:54 PM
vtec02
May 9, 2007 05:17 AM
rajantsr
Jul 13, 2006 05:58 PM
00sithrottle
May 12, 2005 10:25 AM
