obd2 legal
I need to get an 97 civic to pass emissions inspection. It has a p30 ecu, that I know is only obd1. It has a b16a dohc vtec engine. Is there an ecu to plug in and read out yhe aldl connector. If so what ecu code is it and what other misteries am I in for.
I assume you have a OBD2a-OBD1 conversion harness with the p30, correct?
I don't think the OBD2 reader you are mentioning will work with the p30 (as you may already know). Get a 99-00 Civic Si ecu and a OBD2a-OBD2b conversion harness and you should be without any CELs at that point.
rx9790
Nov 23, 2005 12:12 PM
rx9790
Oct 28, 2005 11:30 AM
