OBD1 engine running on a OBD2 ecu
Old Feb 16, 2010 | 04:18 PM
burnindesirez02's Avatar
Default OBD1 engine running on a OBD2 ecu
I know there problems with this..i am wondering if i get an OBD2 ecu such as a P2P then could i say, get a Hondata S300 chip to add to it and make it run without trouble codes?
Old Feb 16, 2010 | 05:44 PM
You cannot chip OBD2 ECUs.
What are the trouble codes you speak of?
Old Feb 16, 2010 | 06:50 PM
well i know of the Crankshaft position code being thrown because of the lack of one in a OBD1 engine.
Old Feb 16, 2010 | 08:41 PM
what he is trying to say is,
he has a obd1 b16 engine in his obd2 car, he wants to be able to put a obd2 ecu in the car so he can pass emmisions, i told him that he can put the obd2 ecu in it but the obd1 engine lacks the cps sensor and will throw a cel on the obd2 ecu, so he will need to do the bypass trick so he wont have a cel. the emmisions people said he needs to have the obd2 ecu hooked up in his car so they can hook the obd2 scanner up to it for him to be able to pass.
Old Feb 16, 2010 | 08:47 PM
Awe...Mitch you know exactly what i need, haha but its not for the emissions anymore if your gonna be able to help me out. Its really because i want to be able to have the ability of OBD2 because its easier to read and erase codes.
Captain_Sl0w
Aug 19, 2008 06:41 PM
98HatchVtecRatio
Nov 26, 2007 04:41 PM
Zer0Ale
Sep 26, 2006 07:14 AM
rx9790
Nov 23, 2005 12:12 PM
1995CivicDx
Sep 27, 2004 10:37 PM
