Re-setting the ECU ?
Old Mar 22, 2005 | 06:09 PM
Jippo99's Avatar
Default Re-setting the ECU ?
To re-set the ECU is it really as simple as disconnecting the negative from the battery?
Old Mar 22, 2005 | 06:39 PM
sacicons's Avatar
Default RE: Re-setting the ECU ?
and let it sit for 20-30 minutes, then plug it back in and start it and let it idle for about 5 minutes with no load on it. if you can find the fuse to pull, then you wont have to reset your radio as well. itll be in the fusebox under the hood.
Old Mar 23, 2005 | 11:26 AM
Jippo99's Avatar
Ok, thanks sacisons. never knew it was that easy
also what benifits would i get from doing that?
Old Mar 23, 2005 | 11:51 AM
polo708's Avatar
you will have to touch the positive and negative battery terminals together (away from the battery of course) then start it and let it idle for about 10 minutes.
Old Mar 23, 2005 | 02:33 PM
Remmy's Avatar
that wouldnt happen to get my check engine light off will it?
Old Mar 23, 2005 | 10:23 PM
sacicons's Avatar
if theres not a real problem it should. and you dont have to wait if you touch the cables together.
civicninja98
Oct 12, 2006 07:08 PM
2002coupe
Dec 7, 2005 09:11 AM
dkcanuck
Sep 9, 2005 08:40 PM
Varvaros
May 28, 2005 01:08 AM
CivicEK4
Nov 23, 2004 08:12 PM
