re tuning
Old Sep 20, 2007 | 07:50 PM
importguy60's Avatar
Default re tuning
ok when is it nesscesary to get your car retuned?? like if you change any little part of your turbo setup do you need to go get a retune?? thanx for the help in advance
Old Sep 21, 2007 | 03:27 AM
Default RE: re tuning
ORIGINAL: importguy60
depends on what that "little part" is
Old Sep 21, 2007 | 03:49 AM
well ok i changed the header and wastegate from a 38mm to a 42 mm and left everything else alone! but thats what i did. ok so here is the ? refrased what components would entail the need for a retune??
Old Sep 21, 2007 | 03:52 AM
I'm not going to sit here and list everything that would require a retune and why. That is a big part of the research that you should be doing on your own.
As for specifics, what is the difference between the manifold (not header) that you're running now compared to the old one. And, does the wastegate have a different spring in?
machocuda
Jul 2, 2005 09:38 AM
fast93civic
May 24, 2005 06:17 AM
fast93civic
May 5, 2005 11:02 PM
DaveLsi
Apr 7, 2005 02:54 AM
hardunaware
Apr 2, 2005 01:44 PM
