Swapped motor, flashing CEL
Old Mar 26, 2007 | 09:02 AM
Tonymore's Avatar
Default Swapped motor, flashing CEL
Okay, I swapped out a D15Z1 for a D15B7 and replaced my factory P07 for the P06...
Before you tell me to search, know that I already have...came up with some itneresting info but nothing that helped with this particular problem.
When I start the car it idles high, and the CEL flashes.
I have checked the codes and am getting:
3 the MAP code
4 the crank sensor code
13 barometric pressure
I have swapped MAP sensors...tested the crank position sensor via the OHM method in the Haynes manual and it is good...
Have no idea what to do about the # 13 code...book says take to dealer...
I know the D15Z1 has a 5 wire Oxygen sensor where as a D15B7 does not...as far as I know. The D15Z1 also has a sensor (purge control solenoid) on the intake that the B7 does not...when I swapped motors I just swapped that sensor over to the B7 intake...not sure what exactly but maybe that is the cause of my problem?
Any sugestions?
WellFedHobo
30
Feb 1, 2012 06:30 AM
fongcom
Feb 9, 2011 03:02 AM
FireFace
Feb 25, 2010 06:21 AM
StonedCold
Jan 20, 2009 12:53 PM
pontiacguy
Sep 12, 2006 11:21 PM
