Throttle Plate Cleaning
Old Sep 20, 2007 | 08:16 AM
kopite's Avatar
Default Throttle Plate Cleaning
Hi guys,
I am new to the forum. I recently purchased(July 5) a 2003 Honda Civic LX one owner. 23,111 miles at time of purchase. Now around 25,100. A couple of weeks ago I took the car for a oil change maintenance check. I was told the car was in good condition. They did recommend throttle plate cleaning. Saying it could reduce mpg. Also said it could be cause by the type of gas the last owner was using. Been doing some research on the topic, it seems possible build up of carbon etc. Want to know what Honda drivers experinces are. I know some dealerships can recommend things which do not need doing or will take 10 minutes and charge you an hour or two labour.
Old Sep 20, 2007 | 09:25 AM
LarsonSi_0091's Avatar
Default RE: Throttle Plate Cleaning
all that is, is that they are telling you to take carb n choke cleaner and take of the intake spray it on the throttle body plate while opening n closing the plate by hitting the throttle like your giving it gas.
Old Sep 20, 2007 | 11:36 AM
xramseyx's Avatar
Agreed with ^^ and welcome to the forums! hope that helps any. Not hard to do, if you wanted to... you could always take off the throttle body and physically clean it. Replacing the gasket of course.
Old Sep 20, 2007 | 01:08 PM
StifflersMom's Avatar
Cat Fuсker
cleaning the TB ain't a big deal at all...and clean the IACV while you're at it too
vmlp
May 9, 2012 03:23 AM
briceman124
Jan 10, 2012 10:12 AM
MistaGlock
Feb 17, 2010 06:31 PM
kijin
Sep 16, 2009 04:18 AM
thakid
Feb 7, 2006 07:51 AM
