b18 swap
depending on what you already have you will need axles, shift linkage, your oem wire harness will work aslong as its a vtec harnessyou may need a new bracket for you throttal cable or you can just cut some of the plastic covering back if you have a vtec ecu most likely p28 that will work fine but eventually you wanna get it chipped or switch it for the p72.
