EG Swaps 1992-1995 Civics
JDM LS swap redling at 5800 rpms
Old Nov 3, 2011 | 01:48 PM
silvertitan22's Avatar
Default JDM LS swap redling at 5800 rpms
I have a 94 civic ex with a jdm b18b swap. Running a stock p75 ecu with no check engine light. it doesn't have a steady idle, bounces from 700 to 1000 rpms and it also redlines at 5800 on my stock eg tach. Anybody ever had this problem or know what it might be? Maybe TPS sensor? Thanks
Old Nov 3, 2011 | 02:37 PM
Newbie2000ex's Avatar
my y8 was had a bouncing idle like that and wouldnt go over 3500.
turned out the tensioner for the timing belt was loose and it slipped 2 teeth in the initial start up. check tdc with a screw driver and check your cam gears for correct timing?
tps sounds like another good place to look into.
Old Nov 4, 2011 | 05:37 PM
Ok thanks. Ill get that checked out.
My99EKHatch
May 5, 2015 10:21 AM
cuongvo85
Apr 22, 2008 01:49 AM
longears
Sep 11, 2007 08:05 AM
4doorcivic9
May 16, 2007 06:56 PM
95 Civic B16A
Mar 18, 2006 11:40 PM
