D16y8 A/T to B16a2 M/T!
I have a 98 Civic EX and i want to swap the motor and tranny.
What all exactly would I need for this?
I know its gonna be a lot, but I'm still kinda learning so be kind please.
Thanks
Thanks
motor tranny ecu, axles, shift linkage, obd2 to obd1 conversion, new wiring harness or modified one. - those are all necessary for the swap. To convert to manual you need pedal set for manual, clutch master cylinder, hydraulic line all the way to the slave cylinder on the transimission. This is going to be a good 3k I would say other things you might want / need hasport motor mounts, short shifter, front engine torque mounts, I dont know about power steering or AC but thats what you need to get it running. A must is to swap distributor cap, rotor, wires plugs, timing belt water pump and clutch I ve done this swap before trust me its easier while its out of the car I did everything but change the clutch and 8 months later it was time for a clutch change, oh headers might be nice to do as well. good luck with the swap.
Captain_Sl0w
Oct 4, 2008 03:05 AM
tvsethi
Jan 26, 2008 09:26 PM
