1984 honda civic motor problems
Old Nov 3, 2008 | 01:03 AM
nitika's Avatar
Default 1984 honda civic motor problems
the civic has a 1.5 4cyl timing seems to be on ,it has a new timing belt ,seems to be getting fuel. the car try's to start but wont. had it running once but it ran rough , and now wont start but try's, has new plugs and wires,i also have tried advancing the timing with the dist. but still same results ,on TDC rotor was pointing to #4 cyl and I advanced the wires as advised from a previous question. i need this car for work so any and all ideas will be a great help?
Old Nov 3, 2008 | 01:18 AM
knoxville's Avatar
Sounds to me like it might be the valve timing. Set #1 cyl to TDC. Pull the valve cover and check the timing marks on the cam gear. They should be in line with the flat surface of the head, & the valves on #1 cyl should be closed. Sound's like the timing belt might have slipped a cog.
_________
MagneFine
Kilroy
Jun 11, 2015 05:26 PM
austin.morgan005
Jul 18, 2010 03:32 AM
StifflersMom
12
Nov 19, 2009 03:04 PM
frontierguy_nc
Mar 29, 2006 02:03 AM
iSamurai
Dec 9, 2005 06:41 AM
