adding a tach help
I wanted to add a small 2" tach to my cluster, bought one, was reading the hook up directions, and it tells me to hook one of the wires to the NEG side of the coil.................well theres my problem........
this is a 1990 civic 1.5 sedan, I think the coil is built in with the distributor (the HAYNES book I have is CRAP only shows a 87, completly different set up)
So I need to know where the coil is and where is the NEG wire side of the coil
any help? Beuler?
edit: ok after doing some more searching on line I think I have to some how tap into the ECU tach test wire...................a "blue" wire, hmmmmm where the hell is that?
any help? Beuler?
"a "blue" wire, hmmmmm where the hell is that?
Take the panel off the gauge cluste housing. There are two screw cover towards the windshield to do this. The blue wire (I forget) is either on the top right or top left. There's only one. Strip, don't cut the wires, and either wrap them together real well and cover them with electrical tape. Or, if you're the ambitious type, solder them and then electrical tape. 4th Gens + tachs = Da Shiz!
thats what I wanted to do first, thought I had one found, even paid for it on line, but nope, it was sold out from under me. Id much prefer a cluster with a tack
derblott
Sep 4, 2008 09:58 AM
dalifts
Dec 16, 2004 10:34 PM
