B18 Swap?
Old Apr 4, 2007 | 04:20 AM
CrazyM's Avatar
Default B18 Swap?
Hey guy's couple questions: I wanna swap the 89 civic...found this in my local paper..
Acura Integra LS, 1992, 1.8L DOHC, for parts, 212,000 kms, runs well, front body damage, CD, lots of good parts & glass.
what all from it would i need to do the swap?
And what all would i need to buy\make to complete swap?
Thanks
Old Apr 4, 2007 | 06:35 AM
natecivic92's Avatar
Default RE: B18 Swap?
Honda/Acura Swap Guide
Target Car
Source Engine
Parts required from source engine
88-91 HondaCivic
88-91 Honda CRX
ZC
D16A8 (ZC)
D16A9 (ZC)
Direct bolt-in swap, only the engine is required.
B16A 88-91
B18A 90-91
Requiresengine, trans, ecu, half shaft, Axles, shift linkage and Motor Mount Kit.
B16A 92-95
B18C 93-95
B18B 93-95
Requiresengine, B series cable trans, ecu, OBD0 to OBD1 wiring jumper harness, half shaft, axles, shift linkage and Motor Mount Kit.
B18C-R 96-01
B16B-R 96-01
Requiresengine, B series cable trans, ecu, OBD0 to OBD2 wiring jumper harness, half shaft, axles, shift linkage and Motor Mount Kit..
90-91 Acura Integra
B18C 93-95
B16A 92-95
Requiresengine, ecu and OBD0 to OBD1 wiring jumper.
B18C-R 96-01
B16B-R 96-01
Requires engine, ECU andOBD0 to OBD2 wiring jumper harness.
B16A 88-91
Requires engine and ECU only.
92-95Honda Civic/92+ Acura Integra Engine Swap Matrix
Target Car
Source Engine
92-95 Honda Civic
92-95Honda Del Sol
92-95 Acura Integra
B18C 93-95
B16A 92-95
B18B 93-95
Requires engine, trans, ecu, axles, half shaft and shift linkage.
B16A 88-91
Not recommended, easier and cheaper to put B16A 92-95.
B18C-R 96-01
B16B-R 96-01
Requires engine, trans, ecu, OBD2 to OBD1 wiring jumper harness, axles, half shaft and shift linkage.
H22A 92-96
Requires engine, trans, ECU, shift linkage, 94+ Integra axles, Motor Mount kit and 94+ Integra GS-R wiring harness.
96-97 Honda Del Sol
96-01 Acura Integra
B16B 96-01
B18C 96-01
Requires engine, trans, ECU, axles, half shaft and shift linkage.
H22A 92-96
Requires engine, trans, ECU, OBD2 to OBD1 wiring jumper harness, shift linkage, 94+ Integra axles, Motor Mount kit and 94+ Integra GS-R wiring harness.
5G Wiring Information
B16A2 in EG Honda Civic
There are 6 lines to check on
Engine Side
ECU Side
Desciption
Wire Color
Pin/Connection
VTEC Solenoid
Yellow/Green
A4
VTEC Oil Pressure Sensor
Blue (passenger side harness)
D6
VTEC Ground
Black
chassis ground
Knock Sensor
Red/Blue
D3
Evap Purge Power
Yellow/Black
12V power (hot in ON or START)
Evap Purge Solenoid
Red
A20
B18C1 in EG HondaCivic
Check on the following 7 lines to see if everything is there and if they are hooked up right.
Engine Side
ECU Side
Desciption
Wire Color
Pin/Connection
VTEC Solenoid
Yellow/Green
A4
D6
VTEC Ground
Black
chassis ground
Knock Sensor
Red/Blue
D3
Evap Purge Power
Yellow/Black
Evap Purge Solenoid
Red
A20
Secondary Intake Solenoid
Pink/Blue
A17
ECU Pinouts
[align=center]EG series Honda Civic (5G, 92-95) and DC series Acura Integra (3G, 94+)
[/align]
96-00Honda Civic Engine Swap Matrix
[align=left]
Target Car
Source Engine
96-97 Honda Civic
B18C 93-95
B16A 92-95
B18B 93-95
Requires engine, trans, ECU, OBD2 to OBD1 wiring jumper harness, axles, half shaft, shift linkage and 99-00 Civic SI rear engine mount.
B16A 88-91
Not recommended, cheaper and easier to put 92-95 or 96-00 B16A engine.
B18C-R 96-97
B16B-R 96-01
Requires engine, trans, ECU, axles, half shaft, shift linkage and 99-00 Civic SI rear engine mount.
98-00 Honda Civic Si
B16A 92-95
B18C 93-95
B18B 93-95
B18C-R 98-01
B16B-R 96-01
B18B 98-01
[/align]
01+Honda Civic/01+ Acura RSX Engine Swap Matrix
Target Car
Source Engine
2002 Honda Civic SI
K20A2/K20A3
K20A-R (JDM)
Requires engine and ECU.
2001 Honda Civic DX/LX/EX
K20A2/K20A3
K20A-R (JDM)
Requires engine, trans, ECU, axles, engine mounts and shift linkage.
92-96 Honda Prelude/90-97 Honda Accord Engine Swap Matrix
Target Car
Source Engine
92-96 Honda Prelude
90-97 Honda Accord
H22A 92-96
Requires engine andECU.
F20BVTEC 97-01
H22A-S 97-01
H22A 97-01
Requires engine, ECU and OBD1 to OBD2 wiring jumper harness.
97-01Prelude/98-01 AccordEngine Swap Matrix
Target Car
Source Engine
97-01
Honda Prelude
98-01Honda
Accord(4cyl.)
H22A 92-96*
Requiresengine, ECU and OBD2 to OBD1 wiring jumper harness.
F20B 97-01
H22A-S 97-01
H22A 97-01
Requires engine and ECU. *Will not work with ATTS models
Old Apr 4, 2007 | 02:56 PM
CrazyM's Avatar
Thanks for the Info
Old Apr 4, 2007 | 04:07 PM
t34me's Avatar
damn nate, i think you got everything
Old Feb 3, 2008 | 01:08 PM
EKblues's Avatar
thanks nate
Old Mar 15, 2012 | 01:47 PM
zmmerman14's Avatar
Ihave a 2002 Honda accord VIN 1HGCG32642A013358 and had to replace the motor in it with VIN 1HGCG5641XA155212
Reason I putting the VIN in here is cause of getting the check engine light to go out getting 3 error codes one being the knock sensor, replaced the knock sensor twice just because check wiring (car shop did) said wiring was ok. My thinking was maybe the wiring pin might be different on the 2 cars? any ideas I can afford to pay $85.00 a hour to just start digging around.......sigh
error codes are, PO325 (knock sensor bank 1) PO700 (Transmission control system) P1739 (TCM A/T controller circuit)
Just replaced the knock sensor again day ago but cleared the error codes and did no good they cam back, not sure what to do at this point car seems to run great trans may be shifting little funny but that might be me an being used to a 1/2 ton truck. But anyway anyone have any ideas out there where to look or to check out so I can point the mechanic in the right direction.............help please
Old Mar 15, 2012 | 01:58 PM
zmmerman14's Avatar
the motor that we put into the 2002 Honda accord lx was a
2.3L I-4 EFI SOHC (out of a 1999 Honda accord lx) so is this the problem? with the error codes?
Old Mar 16, 2012 | 05:41 AM
Why the hell are you posting in a thread from 2008 regarding a B18 swap which has NOTHING to do with your car?????? Make a new thread in the proper section of the forum.
Old Mar 17, 2012 | 06:05 AM
zmmerman14's Avatar
Default Thank you for the great help and link
Thank you for the great help and link referral for the new guy
Old Mar 17, 2012 | 08:11 AM
Would it be better to just say Make a new thread in the appropriate section? I felt the need to mention the fact you revived a dead thread in case you plan to do it again.
This engine swap, in any chassis has been covered a few times. Locking this now.
mike1990civic
ED-EF Swaps
Dec 13, 2005 10:06 PM
honda4life
Aug 27, 2005 08:13 PM
stang
EK Swaps
Aug 22, 2005 12:24 AM
grncivicvtec
Mar 18, 2005 08:23 PM
grncivicvtec
Feb 25, 2005 01:12 PM
