b18b turbo need good advise....!
Old Jun 22, 2012 | 08:23 AM
Animal_00's Avatar
Default b18b turbo need good advise....!
i have a b18b turbo its running pretty good and healty, on the dyno it did 260hp and 224 trq........
but the only thing that bothers me i have 450 injectors with stock fuel regulater and gsr fuel rail.......
my plans is to go 750 injectors with a good fuel regulater and fuel rail.... but ive heard that would save me gass unless i floor it....?
Old Jun 22, 2012 | 08:42 AM
wtf. Bigger injectors would save you gas?
Get the car re-tuned with the new injectors and you should not be using any more gas than usual as long as your AFRs are the same and the amount of boost has not been touched.
Old Jun 22, 2012 | 04:11 PM
Animal_00's Avatar
Koo I have a moroso 4 qt oil pan taped for turbo u think it would be safe to use on my Ls I kno they use 4 1/2 stock ...
Old Jun 22, 2012 | 05:11 PM
Shandles's Avatar
I've heard the moroso pans are junk, and if you hit something with them, they're done. Steel pans will dent, not aluminum ones. But if you're not riding terribly low, then its no big deal.
Old Jun 23, 2012 | 10:50 AM
Animal_00's Avatar
My car isn't low probably 2 1/2 inch of the ground front bumper n not really shure if the oil pan is aluminum have to look into that .... I really don't trust tapped oil pans for some reason..
**merged posts**
It's steel
Old Jun 24, 2012 | 10:11 AM
Shandles's Avatar
I dont think Moroso makes a steel pan. But I could be wrong. Why would you not "trust" a tapped pan? You've gotta get oil to that turbo somehow!
Old Jun 25, 2012 | 08:59 AM
Animal_00's Avatar
No well I mean taPpung the stock oil pan....
I looked up the oil pan and it says steel..
Old Jun 25, 2012 | 11:44 AM
Well actually the tapped portion of the oil pan is for draining the turbo and return line. The feed would either come from a 3 or 4an braided line off a sandwich plate adaptor, or elsewhere.
Old Jun 25, 2012 | 03:30 PM
Animal_00's Avatar
I kno that but jst don't wana tap in the stock oil pan ... But the moroso is a steel oil pan.. hopefully it won't duck up on me .. since its a 4qt pan nd I will be running a better oil pump you guys think motor would cool down alittle faster or won't get as hot ... I do monthly tune ups i kno waste of money but motor has been reliable for 3 years still going strong..
Old Jun 27, 2012 | 03:54 PM
Shandles's Avatar
cvcrcr, I think I worded that poorly...
02Hatchback
May 6, 2010 05:04 PM
vxhybrid
14
Mar 25, 2008 05:50 PM
k_dogg70
44
Sep 30, 2007 07:33 AM
Live_4it
Mar 12, 2007 07:41 PM
mentaldis0rder
Apr 24, 2006 07:46 AM
