Bad Idle
Old Nov 16, 2004 | 01:07 PM
lukbrw's Avatar
Default Bad Idle
94 Civic EX. Stock 1.6 with 135,000 miles. Lately when I start it, the engine idle will go up and down a couple of times. Then idles just fine. But last night. Did the same thing. Started driving and the car just about died. Any idieas?? Ignition??
Thanks
Old Nov 21, 2004 | 10:46 AM
boyfromcouv's Avatar
Default RE: Bad Idle
sounds like an O2 sensor or mass air flow sensor. Get them checked out.
Old Nov 21, 2004 | 02:50 PM
andryuha's Avatar
Check your distributor, cap, wires and plugs. If your O2 sensor went bad, you would get a check engine warning. Same goes for MAF sensor. IF either of those goes bad, you'll get the codes. Also, a bad O2 sensor, shouldn't give youa rough idle, you will run rich on fuel though.
Old Nov 22, 2004 | 09:58 AM
lukbrw's Avatar
I figured it was ignition. Has new plugs. But I'll go through and do cap/rotor and wires this coming weekend.
Thanks
danstelter
Sep 15, 2013 09:23 AM
soldisnakejv
Jun 19, 2013 06:13 PM
love2cul8r
Jan 23, 2008 08:18 AM
ic892003
Nov 29, 2006 06:53 PM
jbarham
Aug 31, 2006 02:36 PM
