Basic maintenance for 98 Civic EX?
Old Jun 22, 2010 | 03:46 PM
The MH's Avatar
Default Basic maintenance for 98 Civic EX?
I have a 98 Civic EX (A.T.) that had never had anything changed since it was purchased. I've changed the timing belt, had the motor mounts replaced, and I'm about to install a new IACV and O2 sensors. I'm pretty sure that there is alot more that should be done seeing that it is over 10 years old. What all should be replaced, cleaned, etc. to ensure that it is in proper condition?
Old Jun 22, 2010 | 03:52 PM
Plugs, wires, cap, rotor.
Engine oil, ATF, coolant, and power steering fluid.
Any CEL codes? Why are you replacing the IACV and O2 sensors?
Old Jun 22, 2010 | 09:47 PM
The MH's Avatar
yeah those were the codes that came up according to auto zone. Currently trying to fix that by replacing those but I don't believe that's the problem. The guy who checked it was acting like a know it all without allowing me to tell him what we recently had done with the car so I'm doubting his diagnosis.
Old Jun 23, 2010 | 06:40 AM
Reset the ECU by removing 7.5A hood Back Up fuse for a few minutes. Then drive the car and, when the CEL turns on again, pull the codes as described at the CEL link in my signature. Do you still get O2 sensor and IAT codes?
Old Jun 24, 2010 | 11:24 PM
The MH's Avatar
I unhooked the battery to reset the computer, is that the same as removing the fuse? But yeah did that after i replaced the iacv. Still got the cel. Anyway, next im going to replace the cap and router, how much do you think that will run me?
Old Jun 25, 2010 | 05:36 AM
You might be getting o2 sensor codes due to a cracked header. That's really common. But I'd still recommend doing what RonJ recommends with the backup fuse, then using the method he recommends for pulling CEL codes.
Old Jun 25, 2010 | 11:27 PM
The MH's Avatar
heard your pipe would smoke white if the header is messed up.
Spark
Dec 26, 2005 08:41 PM
baddriver86
Sep 13, 2005 08:36 AM
R0ADN00b
Apr 22, 2005 01:51 AM
prznsi
Feb 11, 2005 10:06 AM
Hitman
Jan 26, 2005 07:13 PM
