BIGGEST ENGINE?
Old Mar 30, 2006 | 10:26 PM
Kappa22's Avatar
Default RE: BIGGEST ENGINE?
ORIGINAL: Kedawei
B's have the same mounting points, but you can't bolt a B16 to a D tranny.
Correction: SOME B's have the same mount points. They don't necessarily line up.
Old Mar 30, 2006 | 10:29 PM
MccM's Avatar
ORIGINAL: Kappa22
ORIGINAL: Kedawei
daaayyumm Kedawei got served!
Old Mar 30, 2006 | 11:30 PM
Kedawei's Avatar
What B's don't Kappa? The old craptastic B20s/B21 out of 90-91 preludes?
Old Mar 30, 2006 | 11:39 PM
Kedawei's Avatar
ORIGINAL: AgentofDarkness
ORIGINAL: Kedawei
:edit: Better not poke the bull.
Is that an inside joke? B/C i dont' understand.
Tried to pm you to explain, but you have em turned off. I would explain in here, but that would defeat the purpose of editing, wouldn't it? It was nothing offensive, just trying to avoid a flame war about the b series vs. d series.
Old Mar 31, 2006 | 02:07 AM
Kappa22's Avatar
Stock mounts are a no-go in most cases (or most of them are anyway). Precious few (read: EF + SIR-I) are actually direct, straight, sweet-cheeks, stock-mount bolt-ins. Most others you need to fudge the mounts somehow or another.
Old Mar 31, 2006 | 04:15 AM
Kedawei's Avatar
I just assumed they all used the same mount points, because it's said ANY B is a "direct swap" into an EG and EK. I wasn't considering EFs or EPs, an oversight on my part.
Old Mar 31, 2006 | 02:26 PM
Kappa22's Avatar
Ah. Understandable.
However, even with EG's and EK's, you have to use different mounts in some situations.
Old Mar 31, 2006 | 02:29 PM
Marty's Avatar
The rear mount is the one that you have to change on ek/eg's I think
Old Apr 12, 2006 | 09:47 PM
mattallica's Avatar
Yeah that usually helps. I just assumed you knew. I have an 89 civic w/ a d15a. And I meant...without changing mount locations. And snipe just to let u know i am hard of hearing so it helps when I type in CAPS!!! Dude really! don't you have anything else to do other than be a thread editor-in=chief.[sm=chairshot.gif][sm=headbang.gif][sm=smiley2.gif]
ORIGINAL: Marty
what car do you have?
Old Apr 13, 2006 | 06:02 PM
glada96EX's Avatar
In an EK, you need the rear mount bracket, front left mount bracket (front of tranny) and the A/C bracket all from a 99 si. The mounts are the same its just the brackets that are different. Once again, this is for an EK.
Civic|UnLimiteD
Feb 14, 2007 03:39 AM
TheMoogly
Jul 12, 2006 04:49 PM
sorryociffer
Dec 21, 2005 12:59 AM
leco516
Nov 29, 2005 10:33 PM
civicboy01
Jul 14, 2005 11:44 AM
