Burning Smell at High Speeds
Old Dec 30, 2009 | 01:24 PM
supersize's Avatar
Sir Banned-a-lot
Originally Posted by Cryogenic SI
when i cruise, i smell it.
thats cause i took a **** and put it under your seat..
mine smells like plastic burning, i smell it all the time too, usually when im going faster like on highways, and i noticed it alot more when the heat is on.
Old Dec 30, 2009 | 04:00 PM
Cryogenic SI's Avatar
smells like plastic huh? in-ʞɔnɟing-deed
Old Dec 30, 2009 | 08:46 PM
supersize's Avatar
Sir Banned-a-lot
yup sure does...
speaking of smells, tell your mom to wash her genitals... its starting to get a tuna aroma
Old Dec 30, 2009 | 08:56 PM
jprommel's Avatar
Angry Admin
okay i'm sick of you two dip****s you're both banned **** you all of you omfg
Old Dec 30, 2009 | 09:27 PM
Originally Posted by Clean_Civic_98
Once I let off of the gas, the smell dissipates after about five seconds.
Yea, I think it's your valve seals. Try using some Lucas Oil Stabilizer in your oil. It may help a little bit. Follow the directions on the bottle. Be careful not to overfill your engine's total oil capacity. You'll want to change the oil in most cases but since it sounds like you're burning a little oil so you may be low enough to add the right amount of Lucas without going over capacity. Check your oil level with the dipstick and if it's a little bit over the low mark on the dipstick or lower, just add enough Lucas to bring it up to the full mark on the dipstick.
Lost
Jul 25, 2007 05:47 AM
blackmetal619
Apr 13, 2007 12:05 PM
sbg20307
Feb 19, 2007 11:11 PM
Matty Civics
Sep 23, 2005 10:01 PM
WrongfulWright
Mar 9, 2005 08:36 PM
